d0g Posted May 12, 2011 Author Share Posted May 12, 2011 View of custom backet for rear 80s Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Generic fan grills removed and replaced with refinished (old water cooler) grill. The black contrasts and looks way cooler than the generics in my opinion Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 4 inch pvc elbows obtained from local hardware store will serve as air ducts for cpu radiator Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Elbows were shortened and custom cut G10 fiberglass flanges were epoxied on elbows Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Mounting holes were drilled, the radiator was bolted in place. The assembly was then painted with black metallic. Silver and blue pearl stripes were added to match the mother board. The assembly was then clear coated with high gloss urethane. I also replaced the stock H70 cpu radiator fans with more powerful yet quieter fans. Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 An old burnt power supply was stripped of some of its sleeving and used on the replaced fans Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 The radiator assembly installed Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Lower intake radiator port grill assembly Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Upper exhaust radiator port grill assembly Link to comment Share on other sites More sharing options...
d0g Posted May 12, 2011 Author Share Posted May 12, 2011 Hard drive exhaust grill assembly Link to comment Share on other sites More sharing options...
