mstjuan Posted September 7, 2009 Author Share Posted September 7, 2009 yes mate. cu tom. Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 having a coffe break update. more picture will come in 0 hours as i need to continue the mods i started 5 hours ago and 10 hours more of work to come . Regards Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 uploading today's photos Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 Her is today's log which i took long today since i needed to think for the future. This morning i started doing the bottom tray here is anther pictures. nearly finished but stopped here till the wiring is done. Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 the i continued on sticking the modo tray here is a picture fixed with hot glue all round. After the tray was ready i had to make something one the back of the fridge because if you can notice i don't have enough space to close everything and have the cables in a way that will stay confy. so i started creating a back extension , actually this will act like a shutter for the sealer. Below you will find a step by step photos. after this is where i found a foul the fault is that i have corners there while the shape is round therefore i found this solution this will hold the sealer in place. Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 after that i started on the front side this looks like a photo frame lol. here is already done but not fixed i will seal it as the last thing before the final paint. a photo from the inside More to come during the week Link to comment Share on other sites More sharing options...
PaPang Posted September 8, 2009 Share Posted September 8, 2009 Kudos for the updates! But I should have gone back to my chemical engineering studies because I still don't understand what you are trying to do. I also was a little shocked that you cut the back of the fridge because of the potential for oil leaks. I will definitely have to concentrate more on what you expect or plan to do next. And MstJuan, MORE photos please because it takes a lot to imagine what you are getting at. A picture is truly worth a thousand words, 10 pictures are worth 10,000 words and so on! Cheers and Saludos and more pizza! Link to comment Share on other sites More sharing options...
mstjuan Posted September 8, 2009 Author Share Posted September 8, 2009 i had no other option my friend then cutting the back of the fridge and make some miracle. Link to comment Share on other sites More sharing options...
mstjuan Posted September 9, 2009 Author Share Posted September 9, 2009 HI guys here are some photos of today's work. i will be sealing the back with the help of this product Then i started sealing the back panels more.... more .... then i started painting the undercoat. Link to comment Share on other sites More sharing options...
PaPang Posted September 9, 2009 Share Posted September 9, 2009 Saw the patch on the back, hope it holds up well. You are painting by hand the bottom coat. You will have to sand a lot to get it smooth and glossy, that is for sure, or are you going to give it another finish on the top? Good to see that it is coming together. Cheers and Saludos Link to comment Share on other sites More sharing options...
