Maxession Posted September 3, 2009 Share Posted September 3, 2009 Looks good, keep us updated. (PS; I changed the second last pic (as it was a double) from n°88 to n°90) Link to comment Share on other sites More sharing options...
mstjuan Posted September 3, 2009 Author Share Posted September 3, 2009 After waiting 20 minutes to upload all the pictures i am here about to start today's worklog. I started today by having a mishap, yesterday i was doing that cooler master, the second o and ther e of master broke in my hands. here is a piturce. Now i had to think what the hack i should do. mean while so i don't loose time. i wanted to test the paint factor,in this test i have sended half the perspecs to see the effect of the paint. The Paint used. After the test i thought of using glue to hold from the back side and then i continued on working on the rest of the words, after that i painted. Final result of the first part of paiting. Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 3, 2009 Share Posted September 3, 2009 nice job there like what you have done Link to comment Share on other sites More sharing options...
mstjuan Posted September 3, 2009 Author Share Posted September 3, 2009 during the drying time i started working on the other fan which is on the hd's compartments. which is situated in the door. It's the single fan After taking the measurements needed i started building the the guide and the sides of the fan here is a photo of the cuttings. here is the guide picture with the fan and with all the holes drilled. I will be passing the wire of the fan under the hd heatsink so like this i will not have to make any other holes. now that i am sure of everything i started sticking the part to the door. using a common sealer. now it's in place and we let it dry a little bit. here i am making the cuttings on the front fan. here is after cutting it. Link to comment Share on other sites More sharing options...
mstjuan Posted September 3, 2009 Author Share Posted September 3, 2009 Looks good, keep us updated.(PS; I changed the second last pic (as it was a double) from n°88 to n°90) thanks a lot mate. Link to comment Share on other sites More sharing options...
mstjuan Posted September 3, 2009 Author Share Posted September 3, 2009 Now it time for the upper part of the same door. here is a pic of the corners. After taking all the measurements needed and thinking of how the hack i am going to make this part. and here is the idea i had in mind. here is a picture. . Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 4, 2009 Share Posted September 4, 2009 Nice mod Sir MstJuan, I've learned another tricks here... thanks!!! More power bro! keep it coming... Link to comment Share on other sites More sharing options...
mstjuan Posted September 4, 2009 Author Share Posted September 4, 2009 what trick mate ? Link to comment Share on other sites More sharing options...
mstjuan Posted September 4, 2009 Author Share Posted September 4, 2009 Today i was fielding about the fridge door and here is a picture while on test. I shell make a lot of changes as i don't like the current look an suggestion? Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 4, 2009 Share Posted September 4, 2009 Look's cool man thanks for the update's Link to comment Share on other sites More sharing options...
