MACIEL BARRETO Posted July 30, 2009 Author Share Posted July 30, 2009 MPOHV my friend, I know your talent and how hard to hold their projects and thank you for your words of encouragement, good luck to us both. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted July 30, 2009 Author Share Posted July 30, 2009 Icejon is right! now all my post will have a version in Portuguese to be able to help me in translation, good idea Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted July 30, 2009 Author Share Posted July 30, 2009 Now I am installing the driver of fans in the waist and base of pricipal Morphius, to monitor the temperature and voltage consumed by casemod in addition of course to a style, who thought it wrong that the source would be there! kkkk (Agora estou instalando o controlador de fans, na cintura e base pricipal de MORPHIUS, para poder monitorar a temperatura e voltagem consumidas pelo casemod, além é claro de dar um estilo, se enganou quem pensou que a fonte ficaria ai! kkkk) Link to comment Share on other sites More sharing options...
Mpovh Posted July 30, 2009 Share Posted July 30, 2009 I know where is the PSU and I will not tell !!!! aeuhaeuhaeuaeh =DDD Link to comment Share on other sites More sharing options...
PaPang Posted July 30, 2009 Share Posted July 30, 2009 I thought the power source would go there, anyway I can only guess the second best location. Let's see who is right, Mpovh or me, heh-heh. Maciel, a special favor: could you show me one of your molds used in laying the fiber glass? Especially one of the more complicated ones. I would appreciate it very much. Cheers P.D. Another great idea from Icejon, if the English translation goes awry, someone can correct it exactly as it was meant in Portuguese. Kudos! Why didn't I think of that? Sheesh! Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted July 31, 2009 Author Share Posted July 31, 2009 Papang send some videos for you then, because even through pictures you will not understand the process in the case of fiber, but is simple, the model is ready in CLAY, silicone pour on top, wait for drying, and gypsum added to firmness the silicone mold, ready to order is ready and can be used. Simply place the glass fiber and resin. I see where you find will be the source. kkkkkk abraços Papang mandarei uns videos para você depois, pois mesmo através de fotos você não irá entender o processo, no caso da fibra , mas é simples, o modelo estando pronto em CLAY, despeje silicone em cima , espere secar, e acrecente gesso para dar firmeza ao molde de silicone , pronto a forma esta pronta e pode ser usada. Basta colocar a fibra de vidro e a resina. quero ver você descobrir onde vai ficar a fonte. kkkkkk abraços Link to comment Share on other sites More sharing options...
PaPang Posted July 31, 2009 Share Posted July 31, 2009 Obrigado Maciel, as you might have concluded, I know how to apply fiberglass and resin for commercial/industrial applications (repairing boats, coverings, protective surfaces, etc.) some on surfaces and others using molds. Besides the fumes and that you have to work quickly, the most notable negative part of using fiberglass is that it wants to straighten itself (does no follow sharp curves or corners). I have tried several tricks such as cutting (scoring) the matting half way through its thickness, using clamps, etc, but I cannot get it to bend well. Also I know that resin not interlaced with fiberglass matting is easy to chip and relatively weak. If the fiberglass matting is not applied evenly, the part with less matting is weaker and will eventually deform vs. the parts that have enough matting. Too much and too little resin is also a factor. I have seen statues and other decorative figures made of fiberglass here but they are not made in Cancun, but rather shipped from other parts of Mexico or even from China (the majority). So, you are the closest I have come in contact of a person that can use fiberglass in an artistic manner such as you are doing now. No doubt you have in Morphius a clearly artistic and major work of art. Kudos! This as compared to mine which is more pedestrian but it is a first time I attempt using these materials for a case. I don't need that much hand-holding as I know the elementary, but others who do not know could learn a lot from you. In any case, I suppose that one of your objectives is to teach others the noble art of modding, as do I, and that metal sheeting and acrylic is not the only available materials to do so. I am not a sculpturer as you, but with what you can show me, I am willing to take a stab at it just as another challenge. Tchau! ,Saúde! ,Boa sorte! Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted July 31, 2009 Author Share Posted July 31, 2009 One more step, putting the driver at a Cooler Master 120mm FAN, cooling and everything and that if I exaggerate a little! I arrested the driver with clamps to be very firm. Mais uma etapa, colocando junto do controlador uma FAN 120mm COOLER MASTER , REFRIGERAÇÃO é tudo e nesse caso irei exagerar um pouco! Eu prendi o controlador com braçadeiras , para ficar bem firme. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 3, 2009 Author Share Posted August 3, 2009 Now the part already in the top finishing, adcionado the buttons to connect and disconnect. This will be screws on the other. Agora a parte de cima ja com acabamento, adcionado os botões de liga e desliga. Essa parte vai ser parafusada na outra. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted August 5, 2009 Author Share Posted August 5, 2009 After connecting the cables and arrest the driver of the fans enough time to fit in the upper lower, so that part is completed and will soon be showing the chest of the Hards Morphius and added inside. Depois de conectar os cabos e prender o controlador de fans chega a hora de encaixar a parte superior na inferior, assim essa parte vai se completando e breve estarei mostrando o peitoral de MORPHIUS e acrecentando os hards em seu interior. Link to comment Share on other sites More sharing options...
