asgneto Posted August 9, 2009 Author Share Posted August 9, 2009 Oops! I didn't catch your entry until now, but I think the theme is great and commemorates a great happening. Since I didn't see any master plan, I will wait to see what comes up. Kudos!Cheers/Saludos This is one strategic point for this project. Do not reveal the master plan during the construction phases to ensure the surprise at the final week. show one step at each time. I hope you enjoy it ! Link to comment Share on other sites More sharing options...
asgneto Posted August 17, 2009 Author Share Posted August 17, 2009 Updating ... Phase 2 - First Quarter Status: in progess - production of acrylic parts - 75% Early this week I received the material ordered to build the acrylic pieces of the casemod. After cutting the first pieces, I began to build the cover of the radiator and frontal grill. I also cut several acrylic cubes with 1.0 x1, 0 cm to reinforce the corners of the pieces. They will be bonded with acrylic adhesive (solvent-based chloroform). To help unite and bend the parts, I set up a support with right angles and plywood. The angle of 90 degrees is essential to the perfect fit of the parts. Link to comment Share on other sites More sharing options...
asgneto Posted August 17, 2009 Author Share Posted August 17, 2009 I began the assembling of the acrylic parts by the radiator cover ... First, I did the marking and cutting for the 120mm fans on the top panel. Then the panel was glued to the side pieces making a box. The next step was a cut a support for the radiator and spaces to accommodate the connections of the radiator. The support has a large cut showing the entire area occupied by the fins of the radiator. The support was glued to the box, creating a division in two separate houses. One to accommodate the radiator and another for the fans. For security, I added the small acrylic cubes to reinforce the structure and avoid problems. Finally, I added a system for fixing the radiator allowing it to be removed and installed in the box quickly and smoothly. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 17, 2009 Share Posted August 17, 2009 asgneto, Great job and neatly done worklogs! I sure to learn more about modding with the CM Contest. Cheer and More Power bro! Link to comment Share on other sites More sharing options...
asgneto Posted August 18, 2009 Author Share Posted August 18, 2009 asgneto, Great job and neatly done worklogs!I sure to learn more about modding with the CM Contest. Cheer and More Power bro! Welcome to CM forums and thanks for the comments bro ! Link to comment Share on other sites More sharing options...
kll80 Posted August 18, 2009 Share Posted August 18, 2009 Wow nice, really neat work with the acrylic, good luck in the contest. Link to comment Share on other sites More sharing options...
asgneto Posted August 18, 2009 Author Share Posted August 18, 2009 Wow nice, really neat work with the acrylic, good luck in the contest. Thanks a lot ! I hope you enjoy my casemod ! Link to comment Share on other sites More sharing options...
asgneto Posted August 18, 2009 Author Share Posted August 18, 2009 Updating ... Phase 2 - First Quarter Status: in progess - production of acrylic parts - 85% I started this week mounting the front grill. First of all, I cut all pieces that are part of the grill structure and the 25 strips of acrylic with 2.0 x 47.0 cm and 3mm thick using a "acrylic cutter", square and ruler. Then, the strips were properly sanded to match all in size and format. In addition to the 25 strips reserved for the composition of the grill, it was necessary to cut another 5 strips for the manufacturing of spacers. These extra strips were divided into 52 pieces with 4.0 x 2.0 cm. The spacers, after cut, were united with duct tape in 2 blocks of 26 pieces that were matched using a sanding block and 120 grit sandpaper for metal. With the acrylic strips and spacers in the correct measure, I passed the next stage: assembling the grill. Using the support of 90 degrees, the grill pieces were placed one-by-one, strips and spacers. Once they were all, strips and spacers, perfectly aligned, the acrylic glue was applied (solvent-based one chloroform). After a few minutes of waiting for the glue dry completely, once again I sand on the parts to ensure they were all perfectly aligned. Now, its time to test... Perfect! As desired, the grill fit exact in the case front. Next step was to make a inside finishing panel with space for 3 of 120mm fans. This finishing panel was bonded into the inside face of the grill. Right now, it was necessary to adjust the height of the grill and do the thinning of the external borders to follow the curvature of the front of the case. After almost two hours of boring work with sanding disks, and at the cost of lots of acrylic dust, I finally matched the curvature of the grill with the front of the case. Finally, I put the acrylic cubes to reinforce the structure and grind the edge of the grill frame to facilitate the mounting in the case front. Link to comment Share on other sites More sharing options...
PaPang Posted August 20, 2009 Share Posted August 20, 2009 I just wanted to give a suggestion. You should update more frequently, maybe twice or thrice a week with a little more explanatory texts. First, that would push up your "view" count and second, people can understand better your project steps (get more involved to follow your project and revisit). I am a little befuddled about some of the photos as it is now. Remember, "old school" is attention to detail too! He-he, let's see some more! Cheers/Saludos Link to comment Share on other sites More sharing options...
Mpovh Posted August 20, 2009 Share Posted August 20, 2009 Heey Tino.. fantastic job witch acrilic.. the effect that I'm imagining will be incredible congrats.. ;D Link to comment Share on other sites More sharing options...
