asgneto Posted August 29, 2009 Author Share Posted August 29, 2009 Another unusual (and probably great) Asgneto idea in the making! Now everything will melt except your motherboard northbridge when you overclock, heheh.Now that I am doing led electricals, that base would look great with a led in its side. The "frosty" finish will diffuse light very well indeed! (just my idea when I saw it). Very well done, looks factory made. More please! Cheers/Saludos No hardware melted... not again ! Just joking... so far, I never lost hardware because of overclock. You catch the idea... I'll put 3mm blue LEDs on the "frosty" base. But, this mod is happen only in phase 3. Link to comment Share on other sites More sharing options...
Eddye Posted August 29, 2009 Share Posted August 29, 2009 Excellent casemod, asgneto. As always showing great technique in their work. The staff of GDH is with you. Link to comment Share on other sites More sharing options...
asgneto Posted August 29, 2009 Author Share Posted August 29, 2009 Excellent casemod, asgneto. As always showing great technique in their work. The staff of GDH is with you. Eddye, WELCOME to CM Forum... Thanks for the comments e enjoy the contest threads.... Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 29, 2009 Share Posted August 29, 2009 And I will look for you in the future for more water cooling expertise!!! overall - really great asgneto!!! yes, PaPang was right, the frosted thick acrylic glow with led! Link to comment Share on other sites More sharing options...
asgneto Posted August 29, 2009 Author Share Posted August 29, 2009 Its time to correct a small fail on the CM STACKER design... The lack of an opening in the tray on the motherboard to mount high-performance coolers and waterblocks. Some duct tape, a pen, a ruler and a square ... and ready, the markup for the opening cut is done. The cut was done with the Dremel and cut-off disks #409. After cutting, the finishing was realized with a file and a sheet of sandpaper for metal 220grit. Finally, a piece of rubber U to give a finishing with more "professional" look. Link to comment Share on other sites More sharing options...
PaPang Posted August 31, 2009 Share Posted August 31, 2009 More photos please to understand what you are doing on the new phase! Cheers and Saludos Link to comment Share on other sites More sharing options...
asgneto Posted August 31, 2009 Author Share Posted August 31, 2009 The Phase 3 is already in progress ... I have dozens of photos to edit (to improve the contrast/brightness, reduce the size to 1024x768 and rename in the correct sequence) and post throughout the week. Keep an eye on the log because the updates will be posted online one after another. Link to comment Share on other sites More sharing options...
asgneto Posted September 1, 2009 Author Share Posted September 1, 2009 STAGE 3 - Full Moon This phase includes the following processes: A - Painting B - Electrical System C - Cooling System D - Mounting the case These processes, which have started on 25 August, are all happening in parallel. For example, while the coat of primer dries, I'm soldering some leds. The planned date for the end of this phase is September 10. Although I have photos of the progress of all processes, I'll post all the steps of each process in a sequential manner to facilitate the understanding and organization of ideas. Starting with the painting, the first thing to do is choose the paint color and buy the necessary materials for the process: - Sheets of sandpaper 280, 360 and 400 grit. - Universal Primer - Solvent for paint finish - White Lacquer Paint Other items that I had stored in the workshop that left over from previous projects: - Sheets of sandpaper 600 and 1200 grit - Plastic Sealant - Industrial solvent for primer dilution and cleaning the equipment and parts Noobs, attention to the notice of the solvent! Always wear a mask and goggles. Read the instructions and be careful. Warning translation: Sale prohibited to minors of 18 years old. Inhalation of this product may cause death. Using a drill with a 5mm drill bit and a Phillips screwdriver, I removed all the rivets and screws of the chassis. At the end, after lots os rivets drilled, the Stacker chassis was turned into a large pile of pieces. The smaller parts of the case, were sanded with wet sandpaper while the bigger parts I used industrial solvent and a Stiff-blade knife to remove the heaviest part of the earlier painting before sanding. Once sanded, the pieces were washed with neutral soap and plenty of water. As the metal parts, plastic parts and acrylic also need to be prepared for painting. Likewise, they were sanded and well washed. I decided to use my old 5.25" bay reservoir... This decision will cause some changes in the initial design, but will reduce the demand of time, save money and allow the reuse of a piece of my junkbox. Link to comment Share on other sites More sharing options...
PaPang Posted September 1, 2009 Share Posted September 1, 2009 Asgneto, we must promote you from Padawan to Master Padawan (reserving the top rank for later)! Pieces, no, art forms waiting for a master paint job, yes. Warning translation: Sale prohibited to minors of 18 years old. Inhalation of this product may cause death. Wow, they are really severe in Brazil! Not death but a "very ugly high" might be better. If not, no one will use it! These types of paints are great for professional finishes. The acrylic grill looks like a recipient for some strategic leds. Coldly planned as if you were using a Gantt chart. Experience shows! Me? I attack the easy parts first and leave the hardest until last, a very messy way to do a mod (it shows in my worklog) but you have to be messy to have fun, IMO! Bravo Asgneto, more please! Cheers and Saludos Link to comment Share on other sites More sharing options...
asgneto Posted September 2, 2009 Author Share Posted September 2, 2009 Asgneto, we must promote you from Padawan to Master Padawan (reserving the top rank for later)! Pieces, no, art forms waiting for a master paint job, yes.Warning translation: Sale prohibited to minors of 18 years old. Inhalation of this product may cause death. Wow, they are really severe in Brazil! Not death but a "very ugly high" might be better. If not, no one will use it! These types of paints are great for professional finishes. The acrylic grill looks like a recipient for some strategic leds. Coldly planned as if you were using a Gantt chart. Experience shows! Me? I attack the easy parts first and leave the hardest until last, a very messy way to do a mod (it shows in my worklog) but you have to be messy to have fun, IMO! Bravo Asgneto, more please! Cheers and Saludos I'm still training to master padawan... it is too early to be promoted. We had many problems in Brazil with street children sniffing solvents ... The government changed the legislation and enforcement was more severe for this type of product. It's funny, but when dealing with people who have vision for adaptation (read "mods"), many secrets are revealed before the right time... I read the same observation made by Papang in some forums, while in others I read about other details. Belive ou not, If I join all the comments in just one place, all the secrets would be revealed at once. Link to comment Share on other sites More sharing options...
