sunnyXtremist Posted August 22, 2009 Author Share Posted August 22, 2009 Planning to add this enhancement- another scrap item (removed large tie wrap used for cableTV lines-this is the locking part and i cut the long plastic tie) i'll add this to give details the top part or front of this project. this is how it will look, for me it's nice. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 22, 2009 Author Share Posted August 22, 2009 I started cutting the needed materials for the solarpanel mod- making sure this metal will mend even with metal epoxy. it will be a puzzle to make this mod light, this is the back position and locating the LED placement. the logo... Link to comment Share on other sites More sharing options...
PaPang Posted August 22, 2009 Share Posted August 22, 2009 One's junk is another's treasure! I guess you could have made each of the ex-tie clasps by hand, but why bust your rear end when you can adapt something that already exists. That shows a good eye for finding "hidden treasures"! See noobs? You don't have to spend a month's worth of rent to get something done. Just use your imagination and creativity like sunny here. If you don't use your imagination, you would go out and buy a REAL solar panel for a couple of thousand dollars. Jeez! It is just a mod! As long as it LOOKS like a solar panel is good enough. Of course you have to dirty your hands and do some planning, but that is what modding is all about! Am I correct sunnyextremist? Cheers/Saludos Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 One's junk is another's treasure! I guess you could have made each of the ex-tie clasps by hand, but why bust your rear end when you can adapt something that already exists. That shows a good eye for finding "hidden treasures"!See noobs? You don't have to spend a month's worth of rent to get something done. Just use your imagination and creativity like sunny here. If you don't use your imagination, you would go out and buy a REAL solar panel for a couple of thousand dollars. Jeez! It is just a mod! As long as it LOOKS like a solar panel is good enough. Of course you have to dirty your hands and do some planning, but that is what modding is all about! Am I correct sunnyextremist? Cheers/Saludos I think the third quarter and last quarter of this whole mod will be very dirty and will deal with a lot of leadfumes coming from the soldering iron and lead, filling and painting of the container and dealing with the sattelite stand (needed in this kind of mod - a model wahhhhh). PaPang, whatever will be the outcome, you're still best in all aspect... the oldskul guy (next to me-wah) very straight forward in analysis on the pros and cons here, helping other participating modders what's lacking in their worklog. And for sure I thank you for pushing me to the limit!!! you're just great Oldman!!! (ehe, you're a year older than me i supposed?! and slipperyskip is 10 years older...whatttt?!) Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 CoolerMaster 3 x 120mm stock fan modification Prep for painting- Remove carefully all CoolerMaster logo and product marker. (to be return later upon modification on same place) Remove plastic lock (c-clip, o-ring or just plain round rubber lock)with small pointed tool. after lock or clip, there is a rubber spacer that look like this. do some cleaning with a fine sandpaper. Ready for painting important parts keep it safe and secured. 3 x 120mm modded fan intended on a wiremesh cages just at the side of bucket for cooling purposes. Or will do another mod with fangrills... Metallic silver body, glossy white fan blade. I am still thinking of adding Led on this mod. CoolerMaster Aero 7 fitting and modification It blend well inside. need some lapping here... Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 reserved space. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 And since wiring will be all over the container, let keep if cozy clean and tidy- this guys will do the tricks ribbon cables - one of them with 50wires Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 5. On bended acrylics- I am planning to bend some for this mod. I made a sample so that later if i make one, I don't need to have a worklog of same routine, thanks.. layout on acrylic, at 20mm interval and planning for a 20degrees bend. after a couple of bends at my homebrewed acrylic bender, this is how it looks. checking correct angles. tadah (an original PaPang's expression!) the outcome! more wine please... Link to comment Share on other sites More sharing options...
Cham_E_Lyon TPC Posted August 23, 2009 Share Posted August 23, 2009 Wow looking good! Really a brilliant mind you got there brother! Link to comment Share on other sites More sharing options...
sunnyXtremist Posted August 23, 2009 Author Share Posted August 23, 2009 Wow looking good!Really a brilliant mind you got there brother! thanks bro! Link to comment Share on other sites More sharing options...
