Silver|Star Posted June 16, 2005 Share Posted June 16, 2005 Wooow dud I like the way you mod a Stacker !! I tought this was impossible But I really love your mod ! Keep going !! Link to comment Share on other sites More sharing options...
_ferry_ Posted June 16, 2005 Author Share Posted June 16, 2005 Birthday update I'm currently working on the sidepanels, PSU and some plexiglass parts: Mounted the right side. I've glued some m3 bolts on the back, so they ar'nt visible at the sides. A little misstake was that i didn't tought about the height of the case itself, so i had to remove some parts of the frame where the bolts are mounted. New stuff has arrived -UV blue 8mm plexi - clear 5mm plexi - meshX, as 1 of the first in NL Taping it of and ready to get cut. After cutting/sanding After some olishing the are shining like premod. Don't forget these, thy had te get finished, and the holes ar'nt 100% on a straight line, but note that in worst case that would be 0,1mm difference. These speak for themselves. Link to comment Share on other sites More sharing options...
-=Draven=- Posted June 17, 2005 Share Posted June 17, 2005 Let me be the first to say: Whoa!!! Link to comment Share on other sites More sharing options...
CHEESEWHiZ Posted June 17, 2005 Share Posted June 17, 2005 Oh my god! I love you!!! Looking so hot right now! EDIT: My birthday is on Sunday, pretty sure I'm getting an MX1000. Hopefully sooner for this Friday! Link to comment Share on other sites More sharing options...
RED Posted June 17, 2005 Share Posted June 17, 2005 EEEH Ferry It looks better every time!!! I cant wait to see it live again Groete CM-Benelux Link to comment Share on other sites More sharing options...
merovingian Posted June 17, 2005 Share Posted June 17, 2005 Just when I thought it couldn't have gotten any better. Wow! Link to comment Share on other sites More sharing options...
PowerSlide Posted June 17, 2005 Share Posted June 17, 2005 plz dun stop..i wana see more.. Link to comment Share on other sites More sharing options...
Agent_M Posted June 17, 2005 Share Posted June 17, 2005 this mod looks really good, i love thos mollex grips:) Link to comment Share on other sites More sharing options...
_ferry_ Posted June 17, 2005 Author Share Posted June 17, 2005 Thanks guys This evening i did some progress on the plexi blocks for the atx connector, hope to polish them sunday or monday. Link to comment Share on other sites More sharing options...
firefly858 Posted June 20, 2005 Share Posted June 20, 2005 wow! Looks great! Great use of plexi. Very creative! Keep up the good work. Link to comment Share on other sites More sharing options...
