Jeffrey Stephenson Posted September 6, 2009 Share Posted September 6, 2009 I love your fan mods. Great job. I'm just glad I'm not competing against you guys in the unique class. Link to comment Share on other sites More sharing options...
PaPang Posted September 6, 2009 Share Posted September 6, 2009 If it were not for the ready made CM computer case, slipperyskip would be in the unique class! Sunny, did you use a stencil for the CM logo? Adhesive paper or spray adhesive? It came out fabulous! Ahhh.. too bad you have to go back and work, you really advanced a lot in the project! Cheers and Saludos P.D. You still owe us a pic of how your slide out mobo tray came out. Link to comment Share on other sites More sharing options...
mstjuan Posted September 7, 2009 Share Posted September 7, 2009 i did my training with captain pikar and then i was transfered with captain William if that is not enough i was one of the engineers of apollo 13 wink wishful thinking Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 7, 2009 Author Share Posted September 7, 2009 I love your fan mods. Great job. I'm just glad I'm not competing against you guys in the unique class. up to this minute I was thinking the mod was for the unique (certainly a unique one in my eyes), sorry Sir slipperyskip... I am keeping log on all participant's website, I really want to learn more!!! More power Sir! The fan mods, thanks Sir. If it were not for the ready made CM computer case, slipperyskip would be in the unique class!Sunny, did you use a stencil for the CM logo? Adhesive paper or spray adhesive? It came out fabulous! Ahhh.. too bad you have to go back and work, you really advanced a lot in the project! Cheers and Saludos P.D. You still owe us a pic of how your slide out mobo tray came out. Yes, I was not concentrating on the case at the start, my eyes are all stock up with the woodworks from start to the end... And not even on the model of the CM case I didn't bother to check?!?! It will take the whole month for me to check all your website, especially you PaPang ( you're hiding it!). I print these CM logos on an acetate sheet, like an ads area you can easily change logo!!! Yup, I have my time manager with me in front, what to do next, then that, I am on schedule actually, some worklogs are not posted. Yup, the sliding mobo tray will be schedule on Sept 9, according to my worklog, that nearing end, last will be final painting (I have to put more time with painting because we never see sun here anymore). Saludo Sir PaPang, no Smoking near me! i did my training with captain pikar and then i was transfered with captain William if that is not enough i was one of the engineers of apollo 13 wink wishful thinking Wah, Sir mstjuan, you are over qualified... but this is a charity job actually...ngek! joke. tonight I have more time to check all other worklogs and I hope this internet service provider here is telling the truth about upgrading speed...I have the snail DSL here. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 7, 2009 Author Share Posted September 7, 2009 I couldn't find an inexpensive CoolerMaster PSU at this moment so I settle for this... now another redesigning occur, wahhh... and this rain will never stop, my mind won't work... I am SUNNY remember... Link to comment Share on other sites More sharing options...
PaPang Posted September 7, 2009 Share Posted September 7, 2009 Now this modification is going to be good as you have round surfaces to work with, suwerte! (Same almost as in Spanish-suerte). Even a loaned used CM psu would have worked better. Ahhh, the challenges toward the end.... Cheers and Saludos Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 7, 2009 Author Share Posted September 7, 2009 Now this modification is going to be good as you have round surfaces to work with, suwerte! (Same almost as in Spanish-suerte). Even a loaned used CM psu would have worked better. Ahhh, the challenges toward the end....Cheers and Saludos Yup PaPang, I am still checking out for a CM PSU and that will save me some time...but challenges, yes that's another thing (I'll try to make a Cooldrive enclosure outside that looks like a remote part of the Satella). yes suwerte. Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 8, 2009 Author Share Posted September 8, 2009 Updating on what I've done so far for the CM Contest... I've made a wrong holes- The hole for mounting the antenna stands are not align with the left and right side. what I did was... put a hole in every place i'll just add new tricks on the other holes... Sliding Mobo tray with roller (will not be implimented due to lack of time and none ITX board usage) instead, sliding Mobo tray manual type (screw dependent) and still good. after posting, back to the modding room ( Silent Please) Note: I will continue that Sliding Mobo tray with roller after I change the Mobo to an ITX board. maybe after the Contest. Link to comment Share on other sites More sharing options...
PaPang Posted September 8, 2009 Share Posted September 8, 2009 Fantastic effect with the clips! Yes, many fancy things we wanted to do will not be possible. I too will be abbreviating some things in order to finish! "Practical" is the word now! Cheers and Saludos Link to comment Share on other sites More sharing options...
sunnyXtremist Posted September 9, 2009 Author Share Posted September 9, 2009 Fantastic effect with the clips! Yes, many fancy things we wanted to do will not be possible. I too will be abbreviating some things in order to finish! "Practical" is the word now!Cheers and Saludos Thanks about the clips, t'was really helpful to the front. Now I can really feel the pressure of the ticking clock..."Practical" is the word now! Adding updates from previous post... Completion of the Mobo tray setup... Screw holes for the PSU holder/cooler Screw holes for the HDD holder/cooler Screw holes for mounting the lexan tray holder, acrylic Mobo tray, the HDD and PSU holder/cooler Mounting HDD holder/cooler Mounting PSU holder/cooler Trying stability of those screws. And finally, whoooew...I can breath heavily now... Bended and ready for final fitting (whole system can be taken out easily for repair or upgrade). It's raining here Link to comment Share on other sites More sharing options...
