asgneto Posted September 24, 2009 Author Share Posted September 24, 2009 Yes they are GIGANTIC, probably would not fit in OVNI, but did they just arrive? If it is the case, good for the sponsorship but good for the extension to use them!Cheers and Saludos Yes, it came late because of the strike of the postal service in Brazil. And I still have other items that must arrive much later. Thanks ! Link to comment Share on other sites More sharing options...
asgneto Posted September 24, 2009 Author Share Posted September 24, 2009 Updating ... How I got extra time with the extension of the deadline, I decided to give a special touch the top cover ... Remember the holes in the previous update? So let's see how the work was that part of the case ... - Mounting LEDs for finishing the top cover. I did an assembly with the resistors all together for the LEDs on the top cover. Like I always do, I used a 470 Ohm resistor for LED, linking each individual one. The assembly was made with a ribbon cable for floppy and blue LEDs of 3mm. After soldering the wires, resistors and LEDs, I tried to distribute the LEDs through the holes and stake everything with hot glue on the inside of the top cover. You see, since the case back to the original position, the assembly is totally out of reach of curious eyes ... After setting the LEDs and resistors, I put the case into right position and mounted the top cover and finishing. Also mounted in front the logo (provisional) with backlight. A few adjustments in the height and position of the LEDs with a few fingers burned by hot glue (no pictures because I forgot to take them because I'm cursing the hot glue) and ready ... (almost) Final version of the top cover ... Detail: top finishing with the white fan turned off and on .. Overview: Front of case with the white fans turned off ... Note: I put the fan controller in the first bay, just below the logo, and it came to life with plenty of light from the backlight. It was very beautiful with the blue glow ... Detail: base with lighting corrected ... the fugitive LED (identified in the photos of the previous update), fixed on the inside part of the base. The brightness are much more intense now. To finish the post, they are two options for the logo with backlight ... 1) LUNAR SERENITY 2) ASGNETO Casemods Which is the best option ? Link to comment Share on other sites More sharing options...
PaPang Posted September 24, 2009 Share Posted September 24, 2009 Asgneto Casemods! Cheers and Saludos Link to comment Share on other sites More sharing options...
asgneto Posted September 24, 2009 Author Share Posted September 24, 2009 Asgneto Casemods!Cheers and Saludos Thanks PaPang... Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 24, 2009 Share Posted September 24, 2009 nice paint job Link to comment Share on other sites More sharing options...
asgneto Posted September 24, 2009 Author Share Posted September 24, 2009 nice paint job Thanks nicky !!! Link to comment Share on other sites More sharing options...
nicky_82uk Posted September 24, 2009 Share Posted September 24, 2009 no problem man Link to comment Share on other sites More sharing options...
PaPang Posted September 24, 2009 Share Posted September 24, 2009 Now that I paid more attention on my second pass of the progress on page 10, with all those leds, I think it would be nice if they had some movement (atleast a part of them) and by your question on my thread, I think the electrical diagram of my no so good, but simple kit might help you in future projects. Since you have a good grasp of using bread boards, it should not be so difficult to add a few ICs and capacitors to make fantastic moving lights. Hasta la vista, all is looking good up to now. Cheers and Saludos P.D. I will upload a better image later, internet is very bad now. Link to comment Share on other sites More sharing options...
LeandroJVarini Posted September 25, 2009 Share Posted September 25, 2009 wow beautiful work! congratulations Link to comment Share on other sites More sharing options...
asgneto Posted September 25, 2009 Author Share Posted September 25, 2009 Now that I paid more attention on my second pass of the progress on page 10, with all those leds, I think it would be nice if they had some movement (atleast a part of them) and by your question on my thread, I think the electrical diagram of my no so good, but simple kit might help you in future projects. Since you have a good grasp of using bread boards, it should not be so difficult to add a few ICs and capacitors to make fantastic moving lights. Hasta la vista, all is looking good up to now. Cheers and Saludos P.D. I will upload a better image later, internet is very bad now. Nice tip PaPang ! I liked the diagram and I believe that can be useful in my next project. Image saved in "Ideas" folder. wow beautiful work! congratulations Thanks Leandro !!! Link to comment Share on other sites More sharing options...
